If both the HP Teradici CAS+ PCoIP Graphics Agent and HP ZCentral Remote Boost Sender are installed on a Linux system, the rgsender service goes into an indefinite restart loop, causing excessive logging, and some CPU consumption. This only happens when a PCoIP session is active.
- ${title}
- ${title}
- ${title}
- ${title}
Document ID: c08142929
Version: 1
HP ZCentral Remote Boost Sender and Teradici CAS+ PCoIP Graphics Agent - Conflict when both installed on Linux
Notice: The information in this document, including products and software versions, is current as of the release date.The document is subject to change without notice.
Release date : 03-Mar-2022
Last updated : 03-Mar-2022
Systems
HP ZCentral Remote Boost V22.0 and V20 versions
HP Teradici CAS+ PCoIP Graphics Agent all versions
Operating Systems
Red Hat Enterprise Linux 7
Red Hat Enterprise Linux 8
CentOS 7
CentOS 8
Ubuntu 18.04
If both HP ZCentral Remote Boost and HP Teradici CAS+ are required to be used on the same Linux system, perform one of the following options:
Option 1: Upgrade HP ZCentral Remote Boost sender to version 22.1, or 20.4.
Option 2: Modify the
rgsender.service file to prevent both services from running simultaneously. This will persist after reboots:
SSH to the Linux system or open a terminal window.
Edit the following file as admin: /usr/lib/systemd/system/rgsender.service.
Modify the [Unit] section as follows:
Description = HP Remote Boost Sender Service
After = display-manager.service
Before = pcoip.service
Conflicts = pcoip.service
Restart the computer, or run: sudo systemctl restart rgsender.
If HP Remote Boost is not going to be used on the same Linux system, perform one of the following options:
Option 1: Uninstall HP ZCentral Remote Boost sender.
Option 2: Shut down the
rgsender service by doing a
sudo systemctl stop rgsender from a terminal window.
note:You need to do this after every reboot.
After these changes, the
rgsender service will no longer start if the PCoIP service is enabled/running. This will prevent the restart loop.
Hardware platforms affected :
HP ZCentral Remote Boost 2020 Standard E-LTU
Support Communication Cross Reference ID : IA08142929
© Copyright 2022 HP Development Company, L.P.
HP Inc. shall not be liable for technical or editorial errors or omissions contained herein. The information provided is provided "as is" without warranty of any kind. To the extent permitted by law, neither HP or its affiliates, subcontractors or suppliers will be liable for incidental, special or consequential damages including downtime cost; lost profits; damages relating to the procurement of substitute products or services; or damages for loss of data, or software restoration. The information in this document is subject to change without notice. HP Inc. and the names of HP products referenced herein are trademarks of HP Inc. in the United States and other countries. Other product and company names mentioned herein may be trademarks of their respective owners.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
