Victus by HP Laptop 16-d0004sl Product Specifications
602G3EA
Intel® Core™ i5-11400H (up to 4.5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores, 12 threads)
Intel® HM570
16 GB DDR4-2933 MHz RAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce RTX™ 3050 Ti Laptop GPU (4 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
40.9 cm (16.1") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 5Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.1; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
37 x 26 x 2.35 cm
2.46 kg
200 W Smart AC power adapter
4-cell, 70 Wh Li-ion polymer
Battery life mixed usage
Up to 6 hours and 30 minutes
Video Playback Battery life
Up to 9 hours and 45 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by B&O; Dual speakers; HP Audio Boost
FreeDOS
