OMEN by HP Laptop 16-b0127TX Product Specifications
4Y0W7PA
Intel® Core™ i7-11800H (up to 4.6 GHz with Intel® Turbo Boost Technology, 24 MB L3 cache, 8 cores, 16 threads)
Intel® HM570
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce RTX™ 3060 Laptop GPU (6 GB GDDR6 dedicated)
1 TB Intel® PCIe® NVMe™ M.2 SSD
40.9 cm (16.1") diagonal, QHD (2560 x 1440), 165 Hz, 3 ms response time, IPS, micro-edge, anti-glare, Low Blue Light, 300 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 Thunderbolt™ 4 with USB4™ Type-C® 40Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.1; 1 mini DisplayPort™; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36.92 x 24.8 x 2.3 cm
Starting at 2.3 kg
230 W AC power adapter
4-cell, 70 Wh Li-ion polymer
Battery life mixed usage
Up to 5 hours and 30 minutes
Video Playback Battery life
Up to 6 hours and 30 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; DTS:X® Ultra; Dual speakers; HP Audio Boost
Windows 10 Home 64 – free upgrade to Windows 11 when available
