HP Laptop 15s-eq1541AU Product Specifications
4P5H5PA
AMD Ryzen™ 3 4300U (2.7 GHz base clock, up to 3.7 GHz max boost clock, 4 MB L3 cache, 4 cores)
Video graphics
  • AMD Radeon™ Graphics
  • Integrated
512 GB PCIe® NVMe™ SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
35.85 x 24.2 x 1.79 cm
Starting at 1.7 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 15 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Audio
Dual speakers
Windows 10 Home
