    We are upgrading our website
    If you experience errors during this time, please try again later. Sorry for the inconvenience.
    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Computer features
This chapter provides you with an overview of your computer's features.
Standard configuration features
To identify a typical computer configuration, read this section. Features vary depending on the model. For support assistance and to learn more about the hardware and software installed on your computer model, run the HP Support Assistant utility.
Standard configuration of the computer
Front
Use the illustration and table to identify the components on the front of the computer.
Identifying front components
Identifying the front components
Front panel components
1
Microphones
3
Camera
2
Camera light
4
Power light
Left side
Use the illustration and table to identify the components on the left side of the computer.
Identifying left side components
Identifying the left side components
Left side components
1
USB SuperSpeed 5 Gbps port with HP Sleep and Charge
2
Audio-out (headphone)/Audio-in (microphone) combo jack
Rear components
Use the illustration and table to identify the components on the rear of the computer.
Identifying rear components
Identifying the rear panel components
Rear components
1
Power button
5
Power connector
2
Security cable lock
6
USB ports (2)
3
HDMI port
7
USB SuperSpeed port
Use a standard USB Type-A charging cable or cable adapter (purchased separately) when charging a small external device such as a smartphone.
4
RJ-45 (network) jack
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available when contacting customer service for assistance.
Locating the serial number
Security cable lock
You can secure the computer with a security cable lock (purchased separately).
Attaching a cable lock
