HP ENVY x360 Convert 15-es0019nia Product Specifications
4S984EA
Intel® Core™ i5-1135G7 (up to 4.2 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-3200 MHz RAM (2 x 4 GB)
Video graphics
  • Intel® Iris® Xᵉ Graphics
  • Integrated
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, Corning® Gorilla® Glass NBT™, 250 nits, 45% NTSC
Intel® Wi-Fi CERTIFIED 6™ AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 Thunderbolt™ 4 with USB4™ Type-C® 40Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate; 1 HDMI 2.0b; 1 AC smart pin; 1 headphone/microphone combo
35.9 x 22.82 x 1.84 cm
1.82 kg
65 W Smart AC power adapter
3-cell, 51 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 13 hours and 45 minutes
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost
HP Audio Switch; HP Connection Optimizer; HP QuickDrop
McAfee LiveSafe™; 1-month Adobe free trial offer
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
