    Windows 11 Upgrade Guide
HP Laptop 15s-eq1104nm Product Specifications
3Y0N9EA
AMD Ryzen™ 5 4500U (2.3 GHz base clock, up to 4.0 GHz max boost clock, 8 MB L3 cache, 6 cores)
AMD Integrated SoC
8 GB DDR4-2666 MHz RAM (2 x 4 GB)
Video graphics
AMD Radeon™ Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
Realtek RTL8821CE 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 15 minutes
Video Playback Battery life
Up to 9 hours
Audio
Dual speakers
