HP Laptop 15s-eq2012na Product Specifications
3B2H7EA
AMD Ryzen™ 5 5500U (up to 4.0 GHz max boost clock, 8 MB L3 cache, 6 cores, 12 threads)
AMD Integrated SoC
8 GB DDR4-3200 MHz RAM (2 x 4 GB)
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 9 hours and 30 minutes
Video Playback Battery life
Up to 9 hours
Dual speakers
McAfee LiveSafe™; 1-month Adobe free trial offer
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
