OMEN by HP Laptop 17-ck0055TX Product Specifications
492W4PA
Intel® Core™ i7-11800H (up to 4.6 GHz with Intel® Turbo Boost Technology, 24 MB L3 cache, 8 cores, 16 threads)
Intel® HM570
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce RTX™ 3070 Laptop GPU (8 GB GDDR6 dedicated)
1 TB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
17.3" diagonal, QHD (2560 x 1440), 165 Hz, 3 ms response time, IPS, micro-edge, anti-glare, Low Blue Light, 300 nits, 100% sRGB
Intel® Wi-Fi 6E AX210 (2x2) and Bluetooth® 5.2 combo (Supporting Gigabit data rate)
1 Thunderbolt™ 4 with USB4™ Type-C® 40Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.1; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
39.71 x 26.2 x 2.7 cm
Starting at 2.78 kg
330 W Smart AC power adapter
6-cell, 83 Wh Li-ion polymer
Battery life mixed usage
Up to 5 hours
Video Playback Battery life
Up to 7 hours
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by Bang & Olufsen; DTS:X® Ultra; Dual speakers; HP Audio Boost
