    Find Windows 11 and Windows 10 support help. Click here
OMEN Laptop 15-ek0016ua Product Specifications
423K0EA
Intel® Core™ i5-10300H (2.5 GHz base frequency, up to 4.5 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® HM470
16 GB DDR4-2933 MHz RAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 1660 Ti (6 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), 144 Hz, 7 ms response time, IPS, micro-edge, anti-glare, 300 nits, 72% NTSC
Intel® Wi-Fi CERTIFIED 6™ AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.0a; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.79 x 23.97 x 2.25 cm
2.46 kg
200 W Smart AC power adapter
6-cell, 70.9 Wh Li-ion polymer
Battery life mixed usage
Up to 5 hours and 30 minutes
Video Playback Battery life
Up to 7 hours and 15 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by Bang & Olufsen; DTS:X® Ultra; OMEN Audio Control Support DTS:X® Ultra; Dual speakers; HP Audio Boost 2.0
FreeDOS
