HP Laptop 15s-eq1516AU Product Specifications
428A8PA
AMD Ryzen™ 5 4500U (2.3 GHz base clock, up to 4.0 GHz max boost clock, 8 MB L3 cache, 6 cores)
8 GB DDR4-2666 MHz RAM (1 x 8 GB)
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ TLC M.2 SSD
15.6" diagonal, HD (1366 x 768), micro-edge, BrightView, 220 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
35.85 x 24.2 x 1.79 cm
Starting at 1.7 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
Windows 10 Home in S mode
McAfee LiveSafe 30-day free trial offer
