HP Spectre x360 Convertible 14-ea0037nw Product Specifications
365J6EA
Intel® Core™ i7-1165G7 (up to 4.7 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores)
Intel® Integrated SoC
16 GB LPDDR4x-3733 MHz RAM (onboard)
Video graphics
Intel® Iris® Xᵉ Graphics
1 TB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
34.3 cm (13.5") diagonal, WUXGA+ (1920 x 1280), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, Corning® Gorilla® Glass NBT™, 1000 nits, 100% sRGB, HP Sure View Reflect integrated privacy screen
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 Thunderbolt™ 4 with USB4™ Type-C® 40Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 headphone/microphone combo
29.83 x 22.01 x 1.69 cm
1.34 kg
65 W USB Type-C® power adapter
4-cell, 66 Wh Li-ion polymer
Battery life mixed usage
Up to 15 hours and 45 minutes
Video Playback Battery life
Up to 16 hours and 30 minutes
HP True Vision 720p HD IR camera with camera shutter and integrated dual array digital microphones
Audio by Bang & Olufsen; Quad speakers; HP Audio Boost
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
