HP Laptop 15-dw3906ng Product Specifications
48V91EA
Intel® Core™ i3-1125G4 (up to 3.7 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2666 MHz RAM (1 x 8 GB)
Video graphics
Intel® UHD Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek RTL8821CE-M 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
1.75 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours and 15 minutes
Video Playback Battery life
Up to 9 hours
Dual speakers
Windows 10 Home in S mode
HP 3D DriveGuard; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
Alexa; ExpressVPN (30 day free trial)
