    Windows 11 Upgrade Guide
Product Specifications for the HP ENVY 6034e All-in-One Printer (2K4W2A)
Product naming
Model name
2K4W2A
What's included and accessories
What's in the box
HP ENVY 6034e All-in-One Printer; HP 67 Setup Black Cartridge; HP 67 Setup Tri-Color Cartridge; Regulatory flyer; Setup guide; Reference guide; Power cord [For ink volume and page yield information, visit http://hp.com/go/learnaboutsupplies]
Accessories
None
Connectivity
Ports
1 Hi-Speed USB 2.0; 1 Wi-Fi 802.11ac (dual band)
Wireless capability
Yes, built-in Wi-Fi 802.11b/g/n
Copy
Copier settings
Color, mono
Color copy capability
Yes
Maximum number of copies
Up to 9 copies
Copy reduce / enlarge settings
Via HP Smart app
Copy resolution
Up to 300 x 300 dpi
Environmental
Acoustic power emissions (active, printing)
6.5 B(A) (printing at 5ppm)
Acoustic pressure emissions
56 dB(A) (printing at 5ppm)
Recommended operating humidity range
20 to 80% RH (non-condensing)
Non-Operating Humidity Range
Recommended operating temperature range (Celsius)
15 to 30°C
Recommended operating temperature range (Fahrenheit)
59 to 86°F
Storage temperature range (Celsius)
-40 to 60°C
Storage temperature range (Fahrenheit)
-40 to 140°F
Environmental specifications
The HP Envy 6000 All-in-One series is made from recycled printers and other electronics—more than 20% by weight of plastic. Save paper by up to 50% using automatic two-sided printing. Original HP cartridges have been engineered to use recycled plastic and help meet HP’s demanding standards for quality and reliability.
Fax
Fax available
Yes, mobile fax (send only)
Fax features
Option to add files from your phone file/photos, Camera scan or Printer scanner, Option to easily add cover page and save the cover page template, Access to Fax history to see all send faxes and drafts, Ability to edit and resent fax from History, Easily print fax confirmation
Telephone handset supported
No
Fax telephone mode supported
No
Modem
No
Memory
Memory
256 MB DDR3
Maximum Memory
256 MB DDR3
Mobile printing capability
Mobile printing services
Apple AirPrint™; Chrome OS; HP Smart app; Mopria-certified
Paper handling
Input capacity
Up to 100 sheets
Standard input capacity (cards)
Up to 40 cards
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; A5; B5; DL; C6; A6
Media sizes supported (U.S. standard)
Letter, 4 x 6 in, 5 x 7 in, 8 x 10 in, No. 10 envelopes
Media sizes, custom (metric)
Simplex: 76.2 x 127 to 216 x 297 mm; Duplex: 76.2 x 127 to 216 x 297 mm
Media sizes, custom (U.S. standard)
Simplex:3 x 5 to 8.5 x11.7 in; Duplex:3 x 5.5 to 8.5 x 11.7 in
Media types
Plain Paper; HP Photo Papers; HP Matte Brochure or Professional Paper; HP Matte Presentation Paper; HP Glossy Brochure or Professional Paper; Other Photo Inkjet Papers; Other Matte Inkjet Papers; Other Glossy Inkjet Papers; Plain Paper, Light/Recycled
Media weight supported (metric)
A4: 60 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP cards: up to 200 g/m²; HP 10 x 15 cm photo paper: up to 300 g/m²
Media weight supported (U.S. standard)
Letter: 16 to 24 lb; HP envelopes: 20 to 24 lb; HP cards: up to 53 lb; HP 4 x 6 inch photo paper: up to 80 lb
Borderless printing
Yes (up to 8.5 x 11 in, 216 x 297 mm)
Paper handling - duplexer
Media sizes, duplex (U.S. standard)
Letter; Executive
Physical dimensions
Maximum dimensions (W x D x H, metric)
432.5 x 511.5 x 132.1 mm
Maximum dimensions (W x D x H, U.S. standard)
17.03 x 20.14 x 5.2 in
Weight (metric)
5.22 kg
Weight (U.S. standard)
11.51 lb
Power
Built-in Universal Power Supply
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz, 0.7A. Input voltage: 200 to 240 VAC (+/- 10%), 50/60Hz (+/- 3Hz), 0.4A (China & India)
Power consumption
4.0 Watts (Ready) ; 1.70 Watts (Sleep); 0.15 Watts (Off) ; 0.15 Watts (Auto-off)
Print cartridges
Number of print cartridges
2 (1 each black, tri-color)
Replacement cartridges
HP 67 Black Original Ink Cartridge (~120 pages yield) 3YM56AN; HP 67XL Black High Yield Original Ink Cartridge (~240 pages yield) 3YM57AN; HP 67XXL Black Extra High-Yield Original Ink Cartridge (~400 pages yield) 3YM59AN; HP 67 Tri-Color Original Ink Cartridge (~100 pages yield) 3YM55AN; HP 67XL Tri-Color High-Yield Original Ink Cartridge (~200 pages yield) 3YM58AN; HP 67XXL Tri-Color Extra High-Yield Original Ink Cartridge (~330 pages yield) 6ZA16AN. Actual yield varies considerably based on content of printed pages and other factors. For details see https://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic (standard)
Print speed black (ISO)
Up to 10 ppm
Print speed color (ISO)
Up to 7 ppm
Print resolution (best)
Up to 1200X 1200 rendered dpi (when Printing from a computer)
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Regulatory specifications
Regulatory model number
SNPRC-1807-01
Safety
EN 60950-1:2006 +A11:2009 +A1:2010 +A12:2011 +A2:2013 IEC 60950-1:2005 +A1:2009 +A2:2013 EN 62368-1:2014+A11:2017 IEC 62368-1:2014 EN 62479:2010 EN 62311:2008
Electromagnetic compatibility
CISPR 32:2012 / EN 55032:2012 Class B CISPR 32:2015 / EN 55032:2015 Class B CISPR 24:2010 / EN 55024:2010 CISPR 35:2016 / EN 55035:2017 FCC CFR 47 Part 15 Class B ICES-003, Issue 6 VCCI-CISPR 32:2016 EN 301 489-1 V2.1.1:2017 EN 301 489-17 V3.1.1:2017
Telecom compliance (fax capability)
EN 300 328 V2.1.1:2016; EN 301 893 V2.2.1:2017
Scan
Scan technology
CIS
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.7 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, Windows 7 Service Pack 1 (SP1): 32-bit or 64-bit, 2 GB available hard disk space, Internet connection, Internet Explorer.
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
macOS v10.14 Mojave, macOS v10.15 Catalina, macOS v11 Big Sur; 2 GB HD; Internet required
Recommended Macintosh system requirements
Compatible Network Operating Systems
Windows 10, Windows 7 Service Pack 1 (SP1), macOS v10.14 Mojave, macOS v10.15 Catalina, macOS v11 Big Sur, Chrome OS
Manufacturer Warranty
One-year limited hardware warranty; 24-hour, 7 days a week support
