HP Spectre x360 Convertible 13-aw2011ur Product Specifications
2X1W9EA
Intel® Core™ i7-1165G7 (up to 4.7 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores)
Intel® Integrated SoC
16 GB LPDDR4x-3733 SDRAM (onboard)
Video graphics
Intel® Iris® Xᵉ Graphics
1 TB Intel® PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal, 4K UHD (3840 x 2160), OLED, multitouch-enabled, UWVA, edge-to-edge glass, micro-edge, anti-reflection Corning® Gorilla® Glass NBT™, 400 nits, 100% DCI-P3
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 microSD media card reader
2 Thunderbolt™ 4 with USB4™ Type-C® 40Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 headphone/microphone combo
30.67 x 19.45 x 1.69 cm
1.27 kg
65 W USB Type-C™ power adapter
4-cell, 60 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 12 hours
HP True Vision 720p HD IR camera with integrated dual array digital microphones
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial)
