HP Pavilion Gaming Laptop 15-ec2021nr Product Specifications
353L6UA
AMD Ryzen™ 5 5600H (up to 4.2 GHz max boost clock, 16 MB L3 cache, 6 cores)
AMD Integrated SoC
8 GB DDR4-3200 MHz RAM (1 x 8 GB)
Video graphics
  • AMD Radeon™ Graphics
  • Integrated
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal, FHD (1920 x 1080), 144 Hz, IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Intel® Wi-Fi 6 AX200 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 USB 2.0 Type-A (HP Sleep and Charge); 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36 x 25.7 x 2.35 cm
Starting at 1.98 kg
150 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion polymer
Battery life mixed usage
Up to 6 hours
Video Playback Battery life
Up to 9 hours and 15 minutes
Audio by B&O; Dual speakers; HP Audio Boost
Pre-installed software
Netflix
