    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Elite Dragonfly G2 Notebook PC Specifications
Product image
Operating systems
Feature
Preinstalled (Windows)
Windows 10 Pro 64 (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary.
Windows 10 Pro 64 (recommended by HP)
Windows 10 Enterprise 64 (Volume Licensing Agreement)
Windows 10 Enterprise 64 (web support)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Preinstalled (other)
FreeDOS 1.2
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Feature
Intel Core i7-1185G7 Processor
3.0 GHz Base frequency, up to 4.8 GHz with Intel Turbo Boost Technology
12 MB cache and 4 cores
Intel vPro Technology
Intel Core i7-1165G7 Processor
2.8 GHz Base frequency, up to 4.7 GHz with Intel Turbo Boost Technology
Intel Core i5-1145G7 Processor
2.6 GHz Base frequency, up to 4.4 GHz with Intel Turbo Boost Technology
8 MB cache and 4 cores
Intel Core i5-1135G7 Processor
2.4 GHz Base frequency, up to 4.2 GHz with Intel Turbo Boost Technology
Intel Core i3-1115G4 Processor
3.0 GHz Base frequency, up to 4.1 GHz with Intel Turbo Boost Technology
6 MB cache and 2 cores
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Memory
Feature
Standard
LPDDR4X-4266 SDRAM
Supports dual-channel memory
Slots are non-accessible/non-upgradeable
System runs at 4266 MT/s
Configurations
32 GB LPDDR4X-4266 SDRAM
16 GB LPDDR4X-4266 SDRAM
8 GB LPDDR4X-4266 SDRAM
Maximum
32 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Graphics
Feature
Integrated
Intel Iris Xe Graphics
Intel UHD Graphics (for Core i3-1115G4)
Intel Iris Xe Graphics capabilities require system to be configured with Intel Core i5 or i7 processors and dual channel memory.
Supported
HD decode, DX12, and HDMI 2.0
Networking/communication
Feature
Wireless LAN (WLAN)
Intel Wi-Fi 6 AX201 802.11a/b/g/n/ac/ax (2x2) and Bluetooth 5 combo, vPro
Intel Wi-Fi 6 AX201 802.11a/b/g/n/ac/ax (2x2) and Bluetooth 5 combo, non-vPro
Wi-Fi 6 is backwards compatible with prior 802.11 specs.
Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11 WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11 WLAN devices.
WWAN
Intel XMM 7360 LTE-Advanced Cat 9
WWAN module is an optional feature, requires factory configuration and requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds might vary due to location, environment, network conditions, and other factors. LTE not available on all products, in all countries/regions.
Qualcomm Snapdragon X55 5G Cat 20
5G module is an optional feature that must be configured at purchase. Requires activation and separately purchased service contract. Check with service provider for coverage and availability in your area. Connection, upload and download speeds varies due to network, location, environment, network conditions, and other factors. 5G not available on all products, in all countries/regions. Backwards compatible to 4G LTE and 3G HSPA technologies. 5G module is planned to be available in select countries/regions.
Miracast
Yes
Feature
Touch display
33.8 cm (13.3 in) diagonal FHD bent, BrightView WLED UWVA, eDP 1.4 and PSR2, 400 nits, 72% NTSC, touch, Low Power (1920 x 1080)
33.8 cm (13.3 in) diagonal UHD bent, HDR-400, BrightView WLED UWVA, eDP 1.4 and PSR2, 550 nits, 95% sRGB, touch, (3840 x 2160)
33.8 cm (13.3 in) diagonal FHD bent, BrightView WLED UMA, eDP 1.4 and PSR, 1000 nits, 72% NTSC, touch with HP Sure View Reflect integrated privacy screen (1920 x 1080)
HP Sure View integrated privacy screen is an optional feature that must be configured at purchase and is designed to function in landscape orientation.
High-definition (HD) content is required to view high definition images.
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage/drives
Feature
Primary M.2 Solid State Drive storage
128 GB PCIe Gen 3 x2 NVMe M.2 TLC SSD
256 GB PCIe Gen 3 x4 NVMe M.2 TLC SSD
512 GB PCIe Gen 3 x4 NVMe M.2 TLC SSD
1 TB PCIe Gen 3 x4 NVMe M.2 TLC SSD
2 TB PCIe Gen 3 x4 NVMe M.2 TLC SSD
256 GB PCIe NVMe Value M.2 SSD
512 GB PCIe NVMe Value M.2 SSD
256 GB PCIe Gen 3 x4 NVMe M.2 OPAL2 SED TLC SSD
512 GB PCIe Gen 3 x4 NVMe M.2 OPAL2 SED TLC SSD
512 GB Intel PCIe NVMe QLC M.2 SSD with 32 GB Intel Optane memory H10
For solid state drives or hard drives, GB = 1 billion bytes; TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Ports/slots
Feature
Ports
(2) USB USB 3.2 Gen 1 Type-C ports
(1) USB 3.2 Gen 1 Type-A port (charging)
(1) Headphone/microphone combo jack
(1) AC power port
(1) HDMI 2.0 (cable sold separately)
Slots
(1) Nano SIM card slot (not accessible without WWAN)
SIM slot is not user accessible without WWAN configuration.
(1) Nano security lock slot (lock sold separately)
Audio/multimedia
Feature
Audio
Audio by Bang & Olufsen
Internal microphones
Camera (sold separately)
720p HD and IR camera (with integrated electronic privacy shutter)
HP Sure Shutter
The on/off button for HP Sure Shutter is located on the function row of the keyboard.
Sensors
Ambient light sensor
Hall Sensor
Hall sensor
Magnetometer
Gyroscope
Accelerometer
Keyboards/pointing devices/function keys
Feature
HP Modernized Keyboard
Backlit, Spill-resistant, with HP Dura Keys
Pointing device
Glass Clickpad
Microsoft Precision Touchpad default gestures support
Function keys
Function keys
F1 – Display switching
F2 – Blank or Privacy
F3 – Brightness down
F4 – Brightness up
F5 – Audio mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Backlight toggle
F10 – Insert
F11 – Airplane Mode
F12 – HP Command Center (HP Programmable Key)
Num Lock
HP Sure Shutter
Print Screen
Delete
Software/security
Feature
BIOS
HP BIOSphere Gen6 (available on select platforms)
BIOS Update via Network
HP LAN-Wireless Protection
HP Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module
Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Communication/connectivity
HP Connection Optimizer
HP Value add software
Tile app
Available for download from the Windows Store. Mobile phone app available for download from App Store and Google Play.
HP Hotkey Support
HP Sure Recover Gen4 (requires internet connection and not for systems with multiple drives)
HP Sure Click
HP Sure Sense
HP Sure Start Gen6
HP Sure Admin
HP Sure Run Gen4
HP Image Assistant (available for download)
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP Notifications
HP Touchpoint Customizer
HP Privacy Settings
HP Power Manager
HP Wireless Button Driver
HP WorkWell
myHP
HP PC Hardware Diagnostics Windows
HP Pro Security Edition (available on select platforms)
HP QuickDrop
HP QuickDrop requires internet access and Windows 10 PC preinstalled with HP QuickDrop app and either an Android device (phone or tablet) running Android 7 or higher with the Android HP QuickDrop app, and/or an iOS device (phone or tablet) running iOS 12 or higher with the iOS HP QuickDrop app.
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP Client Catalog (available for download)
HP Client Management Script Library (available for download)
HP Management Integration Kit Gen4 (available for download)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Security
HP Client Security Manager Gen7 (requires Windows and available on select platforms)
HP Fingerprint Sensor (sold separately or as an optional feature)
Microsoft Defender (opt in and internet connection required for updates)
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Other standard security features
USB enable/disable (via BIOS)
Secured-Core PC Enable
Support for chassis padlocks and cable lock devices
Power
Feature
Power supply
Adapters
HP Smart 65 W USB Type-C adapter
HP Smart 65 W Slim USB Type-C adapter
Availability might vary by country/region.
Primary battery
HP Long Life 2-cell, 38 Wh polymer
HP Long Life 4-cell, 56 Wh polymer
HP Fast Charge Technology (50% in 30 minutes)
Actual battery Watt-hours (Wh) varies from design capacity. Battery capacity naturally decreases with shelf life, time, usage, environment, temperature, system configuration, loaded apps, features, power management settings and other factors.
Battery is internal and not replaceable by customer. Serviceable by warranty.
Recharges the battery up to 50% within 30 minutes when the system is off or in standby mode. Power adapter with a minimum capacity of 65 watts is required. After charging has reached 50% capacity, charging returns to normal. Charging time varies +/-10% due to System tolerance.
Physical specifications
Feature
Starting at 0.98 kg (2.16 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
30.43 x 19.76 x 1.60 cm (11.98 x 7.78 x 0.63 in)
