HP ENVY Laptop 13-ba1003ur Product Specifications
2X1N0EA
Intel® Core™ i5-1135G7 (up to 4.2 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2933 SDRAM (onboard)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal, FHD (1920 x 1080), IPS, edge-to-edge glass, micro-edge, BrightView, 400 nits, 100% sRGB
Keyboard
Full-size, backlit, nightfall black keyboard
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.69 cm
1.30 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 16 hours and 45 minutes
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphones
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
