    We are upgrading our website
    If you experience errors during this time, please try again later. Sorry for the inconvenience.
    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP ProBook 430 G8 Notebook PC Specifications
Product image
Operating systems
Feature
Preinstalled (Windows)
Windows 10 Pro 64 (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary.
Windows 10 Pro 64 (recommended by HP)
Windows 10 Enterprise 64 (Volume Licensing Agreement)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Preinstalled (other)
FreeDOS 1.2
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Feature
Intel Core i7-1165G7 Processor
2.8 GHz base clock, up to 4.7 GHz with Intel Turbo Boost Technology
4 cores and 12 MB L3 cache
Intel Iris Xe Graphics
Intel Core i5-1135G7 Processor
2.4 GHz base clock, up to 4.2 GHz with Intel Turbo Boost Technology
4 cores and 8 MB L3 cache
Intel Core i3-1115G4 Processor
3.0 GHz base clock, up to 4.1 GHz with Intel Turbo Boost Technology
2 cores and 6 MB L3 cache
Intel UHD Graphics
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Memory
Feature
Standard
(2) DDR4-PC4 SODIMMS
Supports dual-channel memory
System runs at 3200 MT/s
Both slots are customer accessible/upgradable
Configurations
32 GB DDR4-3200 SDRAM (2 x 16 GB)
16 GB DDR4-3200 SDRAM (1 x 16 GB)
16 GB DDR4-3200 SDRAM (2 x 8 GB)
12 GB DDR4-3200 SDRAM (8 GB (1 x 8 GB) and 4 GB (1 x 4 GB))
8 GB DDR4-3200 SDRAM (1 x 8 GB)
8 GB DDR4-3200 SDRAM (2 x 4 GB)
4 GB DDR4-3200 SDRAM (1 x 4 GB)
Maximum
32 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Graphics
Feature
Integrated
Intel Iris Xe Graphics (for Core i5/i7)
Intel UHD Graphics (for Core i3)
High-definition (HD) content is required to view high definition images.
Discrete
NVIDIA GeForce MX450 (2 GB DDR5 dedicated)
Supported
HD decode, DX12, and HDMI 1.4b
Networking/communication
Feature
Wireless LAN (WLAN)
Realtek 802.11ac (2x2) WLAN and Bluetooth 5 Combo
Intel Dual Band Wireless-AC 9560 802.11a/b/g/n/ac (2x2) WLAN and Bluetooth 5 Combo, non-vPro
Intel Dual Band Wi-Fi 6 AX201 802.11a/b/g/n/ac (2x2) WLAN and Bluetooth 5 Combo, non-vPro
Wi-Fi 6 is backwards compatible with prior 802.11 specs.
Wireless access point and internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11 WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11 WLAN devices.
Feature
Non-touch display
33.78 cm (13.3 in) diagonal HD SVA eDP anti-glare, narrow bezel, 250 nits, 45% NTSC (1366 x 768)
33.78 cm (13.3 in) diagonal HD SVA eDP anti-glare, narrow bezel, 250 nits, 45% NTSC for HD camera (1366 x 768)
33.78 cm (13.3 in) diagonal HD SVA eDP anti-glare, narrow bezel, 250 nits, 45% NTSC for HD and IR camera (1366 x 768)
33.78 cm (13.3 in) diagonal FHD UWVA eDP anti-glare, narrow bezel flat, 250 nits, 45% NTSC for HD camera (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD UWVA eDP anti-glare, narrow bezel flat, 250 nits, 45% NTSC for HD and IR camera (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD UWVA eDP and PSR anti-glare, low power narrow bezel flat, 400 nits, 72% NTSC for HD camera (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD UWVA eDP and PSR anti-glare, low power narrow bezel flat, 400 nits, 72% NTSC for HD and IR camera (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD UWVA eDP and PSR anti-glare, narrow bezel flat with HP Sure View Gen3 Integrated Privacy Screen, 1000 nits, 100% sRGB for HD camera (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD UWVA eDP and PSR anti-glare narrow bezel flat with HP Sure View Gen3 Integrated Privacy Screen, 1000 nits, 100% sRGB for HD and IR camera (1920 x 1080)
HP Sure View integrated privacy screen is an optional feature that must be configured at purchase and is designed to function in landscape orientation.
Touch display
33.78 cm (13.3 in) diagonal FHD UWVA eDP anti-glare, narrow bezel flat, touch-on-panel screen, 250 nits, 45% NTSC for HD camera (1366 x 768)
HDMI 1.4b
Supports resolutions up to 4K at 30 Hz
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage/drives
Feature
Primary M.2 Solid State Drive storage
128 GB PCIe NVMe M.2 TLC Solid State Drive
256 GB PCIe NVMe M.2 Solid State Drive
512 GB PCIe NVMe M.2 Solid State Drive
512 GB Intel PCIe NVMe QLC M.2 SSD with 32 GB Intel Optane memory H10
1 TB PCIe NVMe M.2 TLC Solid State Drive
For solid state drives or hard drives, GB = 1 billion bytes; TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Ports/slots
Feature
Ports
(1) USB 3.1 Gen 2 Type-C port (Power delivery, DisplayPort 1.2)
(2) USB 3.1 Gen 1 port (1 charging; 1 powered port)
(1) HDMI 1.4b (cable sold separately)
(1) Headphone/microphone combo jack
(1) AC power input port
Slot
(1) MicroSD (supports SD, SDHC, and SDXC)
(1) Docking connector
Audio/multimedia
Feature
Audio
(2) Integrated stereo speakers
Integrated dual-array Microphone
2 W/4 Ohm per speaker
Camera
720p HD Camera
720p HD and IR Camera (sold separately or as an optional feature)
Keyboard/pointing device/function keys
Feature
Keyboard
HP Premium Keyboard
Spill-resistant
Optional DuraKeys and backlight
Pointing device
ClickPad with multi-touch gesture support
Function keys
F1 – Display switching
F2 – Blank or Sure View on/off
F3 – Brightness down
F4 - Brightness up
F5 - Audio mute/unmute
F6 - Volume down
F7 - Volume up
F8 - Microphone mute/unmute
F9 - Backlight toggle or Blank
F10 - Insert
F11 - Airplane mode
F12 - Programmable Key
Print screen
Power button (with LED)
Hidden function keys
Fn + R - Break
Fn + S - Sys rq
Fn + C - Scroll lock
Software/security
Feature
BIOS
HP BIOSphere Gen5 (available on select platforms with 8th generation processors)
HP Sure Start Gen6 (available on select platforms with 8th generation processors)
BIOS Update via Network
Power On Authentication
Master Boot Record Security
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
Absolute Persistence Module
Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Communication/connectivity
HP Connection Optimizer
HP Value add software
HP Hotkey Support
HP Image Assistant
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HSA Fusion for Commercial
HSA Telemetry for Commercial
Touchpoint Customizer for Commercial
HP Wireless Button Driver
HP WorkWell
myHP
Xerox DocuShare (90-day free trial offer)
HP Notifications
HP Privacy Settings
HP Power Manager
Other products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP Management Integration Kit Gen3 (available for download)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Client Management Script Library (available for download)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Security
HP Client Security Manager Gen6 (requires Windows and available on select platforms)
Microsoft Defender (opt in and internet connection required for updates)
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
HP LAN-Wireless Protection
Other standard security features
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
HP Sure Click (available on select HP platforms and supports Internet Explorer, Google Chrome, and Chromium)
HP Sure Sense (requires Windows)
HP Sure Admin (requires Windows 10, HP BIOS, and HP Manageability Integration Kit)
HP Fingerprint Sensor (optional)
HP Sure Recover Gen3
HP Sure Run Gen3
Support for chassis padlocks and cable lock devices
Power
Feature
Power supply
Adapters
HP Smart 45 W External AC power adapter
HP Smart 45 W USB Type-C power adapter
HP Smart 65 W External AC power adapter
HP Smart 65 W EM External AC power adapter
HP Smart 65 W USB Type-C power adapter
Power cords
3-wire plug - 1.0 m (3.28 ft)
2-wire plug - 1.0 m (3.28 ft)
Availability might vary by country/region.
Primary battery
HP Long Life 3-cell, 45 Wh Li-ion Polymer
Support HP Fast Charge (up to 50% in 30 minutes with 65 W AC adapter)
Actual battery Watt-hours (Wh) varies from design capacity. Battery capacity naturally decreases with shelf life, time, usage, environment, temperature, system configuration, loaded apps, features, power management settings and other factors.
Battery is internal and not replaceable by customer. Serviceable by warranty.
Recharges the battery up to 50% within 30 minutes when the system is off or in standby mode. Power adapter with a minimum capacity of 65 Watts is required. After charging has reached 50% capacity, charging returns to normal. Charging time might vary +/-10% due to system tolerance.
Battery life
Up to 12 hours and 45 minutes (UMA graphics, Intel 11th generation CPU and 3-cell 45 Wh battery)
Battery weight
190 g (0.42 lb)
Physical specifications
Feature
Starting at 1.28 kg (2.82 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
Metal bottom cover
30.68 x 20.83 x 1.30 cm (12.08 x 8.2 x 0.63 in)
Plastic bottom cover
30.68 x 20.83 x 1.75 cm (12.08 x 8.2 x 0.69 in)
