    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Spectre Folio Laptop - 13-ak1021nr Product Specifications
26Z40UA
HP Spectre Folio Convertible 13-ak1021nrBundle
Intel® Core™ i7-10510Y (1.2 GHz base frequency, up to 4.5 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
8 GB LPDDR3-1866 SDRAM (onboard)
Video graphics
Intel® UHD Graphics
  • 512 GB PCIe® NVMe™ M.2 SSD
  • [20,21]
Optical drive
Optical drive not included
13.3" diagonal, 4K UHD (3840 x 2160), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, BrightView, Corning® Gorilla® Glass NBT™, 400 nits, 72% NTSC
Intel® Wi-Fi 6 AX200 (2x2) and Bluetooth® 5.1 combo (Supporting Gigabit file transfer speeds)
2 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 headphone/microphone combo
32.01 x 23.45 x 1.54 cm
1.46 kg
65 W USB Type-C™ power adapter
6-cell, 54.28 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 15 minutes
Video Playback Battery life
Up to 12 hours and 45 minutes
HP Wide Vision 1080p FHD IR camera with integrated dual array digital microphone
Audio by Bang & Olufsen; Quad speakers
HP Connection Optimizer; HP Audio Switch; HP BIOS Protection; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
