    Windows 11 Upgrade Guide
OMEN Laptop - 15-en0038ur Product Specifications
22P28EA
AMD Ryzen™ 7 4800H (2.9 GHz base clock, up to 4.2 GHz max boost clock, 8 MB L3 cache, 8 cores)
AMD Integrated SoC
16 GB DDR4-3200 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce RTX™ 2060 (6 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.0a; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.79 x 23.97 x 2.25 cm
2.47 kg
200 W Smart AC power adapter
6-cell, 70.9 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 11 hours
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by Bang & Olufsen; DTS:X® Ultra; OMEN Audio Control Support DTS:X® Ultra; Dual speakers; HP Audio Boost 2.0
FreeDOS
