    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Getting to know your computer
Your computer features top-rated components. This chapter provides details about your components, where they are located, and how they work.
Right side
Use the illustration and table to identify the components on the right side of the computer.
Identifying the right-side components
Right-side components and their descriptions
Component
(1)
USB SuperSpeed port
Connects a USB device, provides high-speed data transfer, and (for select products) charges small devices when the computer is on.
(2)
AC adapter and battery light
  • White: The AC adapter is connected and the battery is fully charged.
  • Blinking white: The AC adapter is disconnected and the battery has reached a low battery level.
  • Amber: The AC adapter is connected and the battery is charging.
  • Off: The battery is not charging.
(3)
Power connector
Connects an AC adapter.
Left side
Use the illustration and table to identify the components on the left side of the computer.
Identifying the left-side components
Left-side components and their descriptions
Component
(1)
HDMI port
Connects an optional video or audio device, such as a high-definition television, any compatible digital or audio component, or a high-speed High-Definition Multimedia Interface (HDMI) device.
(2)
USB SuperSpeed port
Connects a USB device, provides high-speed data transfer, and (for select products) charges small devices when the computer is on or in Sleep mode.
(3)
USB Type-C® SuperSpeed port with HP Sleep and Charge
Connects a USB device, provides high-speed data transfer, and charges small devices, even when the computer is off.
– and –
Connects a display device that has a USB Type-C connector, providing DisplayPort™ output.
Cables, adapters, or both (purchased separately) might be required.
(4)
Memory card reader (select products only)
Reads optional memory cards that enable you to store, manage, share, or access information.
To insert a card:
  1. Hold the card label-side up, with connectors facing the computer.
  2. Insert the card into the memory card reader, and then press in on the card until it is firmly seated.
To remove a card:
  1. Press in on the card, and then remove it from the memory card reader.
(5)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
  warning:
To reduce the risk of personal injury, adjust the volume before putting on headphones, earbuds, or a headset. For additional safety information, see the Regulatory, Safety, and Environmental Notices.
To access this guide:
  1. Type HP Documentation in the taskbar search box, and then select HP Documentation.
When a device is connected to the jack, the computer speakers are disabled.
The computer display can include essential components such as speakers, antennas, cameras, and microphones.
Low blue light mode (select products only)
Your computer display is shipped from the factory in low blue light mode for improved eye comfort and safety. Also, blue light mode automatically adjusts blue light emissions when you are using the computer at night or for reading.
  warning:
To reduce the risk of serious injury, read the Safety & Comfort Guide. It describes proper workstation setup and proper posture, health, and work habits for computer users. The Safety & Comfort Guide also provides important electrical and mechanical safety information. The Safety & Comfort Guide is available on the web at http://www.hp.com/ergo.
Refer to the illustration that most closely matches your computer.
Identifying the display components
Display components and their descriptions
Component
(1)
WLAN antennas*
Send and receive wireless signals to communicate with wireless local area networks (WLANs).
(2)
Internal microphones (2)
Record sound.
(3)
Camera
Allows you to video chat, record video, and record still images. Some cameras also allow a facial recognition logon to Windows, instead of a password logon.
Camera functions vary depending on the camera hardware and software installed on your product.
(4)
Camera light
On: The camera is in use.
*The antennas are not visible from the outside of the computer. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region.
Keyboard area
Keyboards can vary by language.
Touchpad settings and components
The touchpad settings and components are described here.
Touchpad settings
You learn how to adjust the touchpad settings and components here.
Adjusting touchpad settings
Use these steps to adjust touchpad settings and gestures.
  1. Type touchpad settings in the taskbar search box, and then press enter.
  2. Choose a setting.
Turning on the touchpad
Follow these steps to turn on the touchpad.
  2. Using an external mouse, click the touchpad button.
    If you are not using an external mouse, press the Tab key repeatedly until the pointer rests on the touchpad button. Then press the spacebar to select the button.
Touchpad components
Use the illustration and table to identify the touchpad components.
Identifying the touchpad
Touchpad components and their descriptions
Component
(1)
Touchpad zone
Reads your finger gestures to move the pointer or activate items on the screen.
(2)
Left control zone
Textured area that allows you to perform additional gestures.
(3)
Right control zone
Lights
Use the illustration and table to identify the lights on the computer.
Identifying the lights
Lights and their descriptions
Component
(1)
Caps lock light
On: Caps lock is on, which switches the key input to all capital letters.
(2)
Mute light
  • On: Computer sound is off.
  • Off: Computer sound is on.
(3)
Power light
  • On: The computer is on.
  • Blinking (select products only): The computer is in the Sleep state, a power-saving state. The computer shuts off power to the display and other unnecessary components.
  • Off: Depending on your computer model, the computer is off, in Hibernation, or in Sleep. Hibernation is the power-saving state that uses the least amount of power.
Button, vent, and fingerprint reader
Use the illustration and table to identify the computer button, vent and fingerprint reader.
Identifying the button, vent, and fingerprint reader
Fingerprint readers, which enable a fingerprint logon, can be located on the touchpad, on a side panel of the computer, or on the top cover below the keyboard.
To verify that your computer supports fingerprint reader sign-in, type Sign-in options in the taskbar search box and follow the on-screen instructions. If Fingerprint reader is not listed as an option, then your computer does not include a fingerprint reader.
Button, vent, and fingerprint reader and their descriptions
Component
(1)
Vent
Enables airflow to cool internal components.
The computer fan starts up automatically to cool internal components and prevent overheating. It is normal for the internal fan to cycle on and off during routine operation.
(2)
Power button
  • When the computer is off, press the button briefly to turn on the computer.
  • When the computer is on, press the button briefly to initiate Sleep.
  • When the computer is in the Sleep state, press the button briefly to exit Sleep (select products only).
  • When the computer is in Hibernation, press the button briefly to exit Hibernation.
Pressing and holding down the power button results in the loss of unsaved information.
If the computer has stopped responding and shutdown procedures are ineffective, press and hold the power button down for at least 10 seconds to turn off the computer.
To learn more about your power settings, see your power options:
  1. Right-click the Power icon , and then select Power Options.
(3)
Fingerprint reader (select products only)
Allows a fingerprint logon to Windows, instead of a password logon.
  1. Touch your finger to the fingerprint reader.
    To prevent fingerprint logon issues, make sure when you register your fingerprint that all sides of your finger are registered by the fingerprint reader.
Special keys
Identify the special keys.
Identifying the special keys
Special keys and their descriptions
Component
(1)
esc key
Displays system information when pressed in combination with the fn key.
(2)
fn key
Executes specific functions when pressed in combination with another key.
(3)
Windows key
Opens the Start menu.
Pressing the Windows key again will close the Start menu.
(4)
Action keys
Execute frequently used system functions as defined by the icon symbols on f1 through f12 function keys.
(5)
Power button
Bottom
Use the illustration and table to identify the bottom components.
Identifying the bottom components
Bottom components and their descriptions
Component
(1)
Speakers (2)
Produce sound.
(2)
Vent
Labels
The labels affixed to the computer provide information you may need when you troubleshoot system problems or travel internationally with the computer. Labels may be in paper form or imprinted on the product.
Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
  • Service label—Provides important information to identify your computer. When contacting support, you may be asked for the serial number, the product number, or the model number. Locate this information before you contact support.
    identifying the service label
    Service label components
    Component
    (1)
    HP product name
    (2)
    Model number
    (3)
    Product ID
    (4)
    Serial number
    (5)
    Warranty period
  • Regulatory labels—Provides regulatory information about the computer.
  • Wireless certification labels—Provide information about optional wireless devices and the approval markings for the countries or regions in which the devices have been approved for use.
