    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Illustrated parts catalog
Use this information to determine the spare parts that are available for the computer.
HP continually improves and changes product parts. For complete and current information about supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
Computer major components
To identify the computer major components, use this illustration and table.
Identifying computer components
Computer major components and their descriptions
Item
(1)
Access panel
(2)
Fan
(3)
Optical drive:
DVD-BluRay Drive 9.5 mm UST 6×
DVD+/-RW SM DL 9.5 mm with slim tray
DVD-ROM 9.5 mm with slim tray
Slim optical drive bezel
Slim optical drive blank bezel
Slim optical drive blank bezel with 525
Slim optical drive latch 9.5 mm
(4)
Processor:
Intel™ Core® i7-10700 processor (2.9 GHz, 8 cores, 65 W)
Intel Core i5-10600 processor (3.3 GHz, 6 cores, 65 W)
Intel Core i5-10500 processor (3.1 GHz, 6 cores, 65 W)
Intel Core i5-10400 processor (2.9 GHz, 6 cores, 65 W)
Intel Core i3-10320 processor (3.8 GHz, 4 cores, 65 W)
Intel Core i3-10300 processor (3.7 GHz, 4 cores, 65 W)
Intel Core i3-10100 processor (3.6 GHz, 4 cores, 65 W)
Intel Pentium® Gold G6600 processor (4.2 GHz, 2 cores, 58 W)
Intel Pentium Gold G6500 processor (4.1 GHz, 2 cores, 58 W)
Intel Pentium Gold G6400 processor (4.0 GHz, 2 cores, 58 W)
Intel Celeron® G5905 processor (3.50 GHz 2 cores)
(5)
3.5 in hard drive:
2 TB, 7200 RPM, 3.5 in
1 TB, 7200 RPM, 3.5 in
500 GB, 7200 RPM, 3.5 in
(6)
Primary hard drive cage
(7)
Heat sink with fan, 65 W
(8)
Power supply:
550 W, EPA 92, +12 V
260 W
180 W, EPA 90 (Gold)
(9)
System board (includes replacement thermal material):
Equipped with the NetC and Windows operating systems
Equipped with the NetC operating system
Equipped with the Windows® operating system
Not equipped with an operating system
(10)
Optical drive cage
(11)
Speaker (includes cable)
(12)
System chassis
(13)
Front bezel
Antenna (not illustrated):
Internal dual antenna
Internal single antenna
Antenna cover
Hood sensor (not illustrated)
UDIMM memory module (not illustrated):
32 GB 1.2 V DDR4-3200 NECC UDIMM memory module
16 GB 1.2 V DDR4-3200 NECC UDIMM memory module
8 GB 1.2 V DDR4-3200 NECC UDIMM memory module
4 GB 1.2 V DDR4-3200 NECC UDIMM memory module
32 GB 1.2 V DDR4-2666 NECC UDIMM memory module
16 GB 1.2 V DDR4-2666 NECC UDIMM memory module
8 GB 1.2 V DDR4-2666 NECC UDIMM memory module
4 GB 1.2 V DDR4-2666 NECC UDIMM memory module
Solenoid lock (not illustrated)
WLAN module (not illustrated):
WLAN Intel Wi-Fi 6 AX201 ax 2×2 + Bluetooth® 5.0 non-vPro® WW
WLAN Intel Wi-Fi 6 AX201 ax 2×2 + Bluetooth 5.0 vPro WW
WLAN Realtek RTL8821CE ac 1×1 + Bluetooth 4.2 WW
WLAN Realtek RTL8822CE ac 2×2 + Bluetooth 5.0 M.2 2230 WW
Mass storage devices
To identify the available hard drives, solid-state drives, and optical drives, use this table.
Mass storage devices and their descriptions
3.5 in hard drive:
2 TB, 7200 RPM
1 TB, 7200 RPM
500 GB, 7200 RPM
2.5 in hard drive:
2 TB, 5400 RPM
1 TB, 7200 RPM
500 GB, 7200 RPM
500 GB, 7200 RPM, Federal Information Processing Standards (FIPS)
500 GB, 7200 RPM, self-encrypting drive (SED), OPAL2
M.2 2280 solid-state drive:
2 TB, M.2 2280, peripheral component interconnect express (PCIe), non-volatile memory express (NVMe), Secure Seal (SS) solid-state drive with triple level cell (TLC)
1 TB, M.2 2280, PCIe, NVMe, SS solid-state drive with TLC
512 GB, M.2 2280, PCIe, NVMe, SS solid-state drive with TLC
512 GB, M.2 2280, PCIe, NVMe, value solid-state drive
512 GB, M.2 2280, PCIe-3×4, SED solid-state drive with TLC
512 GB, M.2 2280, PCIe, NVMe + 32 GB, 3D Xpoint solid-state drive
256 GB, M.2 2280, PCIe, NVMe, SS solid-state drive with TLC
256 GB, M.2 2280, PCIe, NVMe, value solid-state drive
256 GB, M.2 2280, PCIe-3×4, SED solid-state drive with TLC
256 GB, M.2 2280, PCIe + 16 GB, 3D Xpoint solid-state drive
128 GB, M.2 2280, PCIe, NVMe, solid-state drive with TLC
16 GB, M.2 2280, PCIe-3×2, NVMe, solid-state drive with TLC
SATA-3 solid-state drive:
512 GB, 2.5 inch, SATA-3, SED solid-state drive with TLC, OPAL2
512 GB, 2.5 inch, SATA-3, solid-state drive with TLC
256 GB, 2.5 inch, SATA-3, SED solid-state drive with TLC, OPAL2
256 GB, 2.5 inch, SATA-3, solid-state drive with TLC
Cables
To identify the computer cables, use this table.
Cables and their descriptions
155 mm (6.1 in) SATA cable, straight-to-reverse angle
155 mm (6.1 in) SATA cable, straight-to-reverse angle, RF solution
280 mm (11 in) SATA cable, straight-to-straight
280 mm (11 in) SATA cable, straight-to-straight, RF solution
305 mm (12 in) SATA cable, straight-to-straight
305 mm (12 in) SATA cable, straight-to-reverse angle, RF solution
450 mm (17.7 in) SATA cable, straight-to-straight
450 mm (17.7 in) SATA cable, straight-to-straight, RF solution
DisplayPort-to-DisplayPort 1.2 cable (1.8 m (6 ft), black)
DisplayPort-to-DVI cable
DisplayPort-to-VGA cable
DVI-to-DVI (D) cable (1.8 m (6 ft), white)
130 mm (5.1 in) SATA power cable, RF solution
SATA power connector cable, 2×3 pin
SATA power connector cable, RF solution
Miscellaneous parts
To identify the various computer parts, use this table.
Miscellaneous parts and their descriptions
Adapter:
HP DisplayPort–to–HDMI 2.0 adapter
USB–to–Serial adapter (Sunix)
Expansion card:
AMD® Radeon® 520 graphics card with 1 GB memory
AMD RX550 CMIT FH graphics card with 4 GB memory
R7430 CMIT FH graphics card with 2 GB memory 2DP
RTX2060 Super CMIT graphics card
IO1 USB Type-C® B2B expansion card
IO1 DP B2B expansion card
IO1 HDMI B2B expansion card
IO1 Thunderbolt™ expansion card
IO1 2× USBA 3G1 B2B expansion card
IO1 VGA B2B expansion card
Intel PRO/1000 Single Port GbE network interface card (NIC)
HP Parallel port PCIe×1 expansion card
USB serial option expansion card
PCIe–to–RS232×1 card expansion card
PS/2+serial port expansion card
2nd serial port expansion card
Power cord:
Power cord, Cert-7A, for use in Japan (black)
Power cord (1.8 m (6 ft), black)
Power cord, C13, 5-15P, for use in Thailand (1.8 m (6 ft), black)
Power cord, C13, 6 amp, for use in India (2.0 m (6.6 ft))
Power cord, C13 with sticker (1.8 m (6 ft))
Power cord, unshielded, domestic (black)
Power cord adapter, Option 949 (ROHS)
