    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP E22 G4 FHD Monitor Product Specifications
Panel
9VH72AA
Display panel type
IPS
21.5"
Panel active area (W x H)
47.6 x 26.77 cm
Resolution
FHD (1920 x 1080)
Aspect ratio
16:9
Brightness (typical)
250 nits
Contrast ratio (typical)
1000:1 static
Response times
5ms on/off (with overdrive)
Pixel pitch
0.247 mm
Display features
On-screen controls; Low blue light mode; Anti-glare
Onscreen controls
User controls
Brightness; Exit; Information; Management; Power control; Input control; Menu control; Image; Color
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1280 x 720; 1280 x 800; 1440 x 900; 1600 x 900; 1680 x 1050; 1920 x 1080; 640 x 480; 720 x 400; 800 x 600
Video/other inputs/cables
Interface
HDMI; VGA; USB hub; DisplayPort
Display Input Type
1 VGA; 1 USB Type-B; 1 HDMI 1.4; 1 DisplayPort™ 1.2; 4 USB-A 3.2 Gen 1
Ergonomics
VESA mount
100 mm x 100 mm
Physical security
Security lock-ready
Power
Input voltage
Input voltage 100 to 240 VAC
Power consumption
50 W (maximum), 23 W (typical), 0.5 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
48.87 x 48.06 x 20.7 cm
Dimensions (W x D x H)
48.87 x 29.46 x 4.7 cm
19.24 x 11.6 x 1.85 in
Product dimensions with stand (W x D x H)
19.24 x 18.92 x 8.15 in
5.3 kg
What's in the box
What's in the box
Monitor; DisplayPort™ 1.2 cable; HDMI cable; USB Type-A to B cable; QSP; AC power cable
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% non-condensing
Certifications and compliances
Australian-New Zealand MEPS; BIS; BSMI; CB; CCC; CE; CECP; CEL; cTUVus; EAC; ENERGY STAR®; FCC; ISE for Cambodia; ISO 9241-307; KC/KCC; NOM; PSB; SEPA; TCO Certified; TUV-S; VCCI; Vietnam MEPS; WEEE; ISC; WW application; ICE; UAE
