    Apache Log4j Update
HP E24 G4 FHD Monitor Product Specifications
Panel
3R473AA
Display panel type
IPS
23.8"
Panel active area (W x H)
52.7 x 29.64 cm
Resolution
FHD (1920 x 1080)
Aspect ratio
16:9
Brightness (typical)
250 nits
Contrast ratio (typical)
1000:1 static
Response times
5ms GtG (with overdrive)
Pixel pitch
0.274 mm
Display features
Low blue light mode; Anti-glare
Onscreen controls
User controls
Brightness; Exit; Information; Management; Power control; Input control; Menu control; Image; Color
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1280 x 720; 1280 x 800; 1440 x 900; 1600 x 900; 1680 x 1050; 1920 x 1080; 640 x 480; 720 x 400; 800 x 600
Video/other inputs/cables
Interface
HDMI; USB port; VGA; DisplayPort
Display Input Type
1 VGA; 1 USB Type-B; 1 HDMI 1.4; 1 DisplayPort™ 1.2; 4 USB-A 3.2 Gen 1
Ergonomics
VESA mount
100 mm x 100 mm
Physical security
Security lock-ready
Power
Input voltage
Input voltage 100 to 240 VAC
Power consumption
51 W (maximum), 26 W (typical), 0.5 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
53.94 x 20.7 x 49.49 cm
Dimensions (W x D x H)
53.94 x 4.7 x 32.33 cm
21.24 x 1.85 x 12.73 in
Product dimensions with stand (W x D x H)
21.24 x 8.15 x 19.48 in
12.54 lb
What's in the box
What's in the box
Monitor; DisplayPort™ 1.2 cable; HDMI cable; USB cable; VGA cable; AC power cable
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% non-condensing
Certifications and compliances
Australian-New Zealand MEPS; BIS; BSMI; CB; CCC; CE; CECP; CEL; cTUVus; EAC; ENERGY STAR®; FCC; ISE for Cambodia; ISO 9241-307; KC/KCC; NOM; PSB; SEPA; TCO Certified; TUV-S; VCCI; Vietnam MEPS; WEEE; ISC; WW application; ICE; UAE
