HP ENVY Laptop - 13-ba0025ur Product Specifications
22M58EA
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2666 SDRAM (onboard)
Video graphics
NVIDIA® GeForce® MX350 (2 GB GDDR5 dedicated)
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal, FHD (1920 x 1080), IPS, edge-to-edge glass, micro-edge, BrightView, 400 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.69 cm
1.3 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion
Battery life mixed usage
Up to 9 hours and 45 minutes
Video Playback Battery life
Up to 14 hours and 15 minutes
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphones
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
