    Fix HP Printer issue on macOS
HP EliteBook x360 1040 G7 Notebook PC Specifications
Product image
Operating systems
Feature
Pre-installed (Windows)
Windows 10 Pro 64 (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary.
Windows 10 Pro 64 (recommended by HP)
Windows 10 Pro 64 (Windows 10 Enterprise available with a Volume Licensing Agreement)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Pre-installed (other)
FreeDOS 1.2
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Feature
Intel Core i7-10810U Processor
1.1 GHz, up to 4.9 GHz with Intel Turbo Boost technology
12 MB cache, 6 cores
Supports Intel vPro technology
Intel UHD Graphics
Intel Core i7-10710U Processor
1.1 GHz, up to 4.7 GHz with Intel Turbo Boost technology
Intel UHD Graphics
Intel Core i7-10610U Processor
1.8 GHz, up to 4.9 GHz with Intel Turbo Boost technology
8 MB cache, 4 cores
Intel UHD Graphics
Intel Core i5-10310U Processor
1.7 GHz, up to 4.4 GHz with Intel Turbo Boost technology
6 MB cache, 4 cores
Intel UHD Graphics
Intel Core i5-10210U Processor
1.6 GHz, up to 4.2 GHz with Intel Turbo Boost technology
6 MB cache, 4 cores
Intel UHD Graphics
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Memory
Feature
Standard
Memory soldered down
Supports dual-channel memory
LPDDR4, system runs at 2933 MT/s
Configurations
32 GB LPDDR4-2933 SDRAM
16 GB LPDDR4-2933 SDRAM
8 GB LPDDR4-2933 SDRAM
Maximum
32 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Graphics
Feature
Integrated
Intel UHD Premium Graphics
Ultra High-definition (HD) content is required to view ultra high definition images.
Supports
HD decode
DirectX 12
HDMI 1.4b
Feature
Touch display (optional)
35.56 cm (14.0 in) diagonal FHD IPS Ultraslim 2.0 mm eDP and PSR2 BrightView touchscreen with 0.4 mm Gorilla Glass 5 , 400 nits, 72% NTSC (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS Ultraslim 2.0 mm eDP and PSR2 anti-glare touchscreen with 0.4 mm Gorilla Glass 5, 400 nits, 72% NTSC (1920 x 1080)
35.56 cm (14.0 in) diagonal UHD OLED IPS Ultraslim 1.21 mm eDP and PSR2 BrightView touchscreen with 0.4 mm Gorilla Glass 5, 400 nits, 72% NTSC (3840 x 2160)
HP Sure View Reflect Integrated Privacy Screen 35.56 cm (14.0 in) diagonal FHD IPS Ultraslim 2.0 mm eDP and PSR BrightView touchscreen with 0.4 mm Gorilla Glass 5, 1000 nits, 72% NTSC (1920 x 1080)
HP Sure View Reflect Integrated Privacy Screen 35.56 cm (14.0 in) diagonal FHD IPS Ultraslim 2.0 mm eDP and PSR anti-glare touchscreen with 0.4 mm Gorilla Glass 5, 1000 nits, 72% NTSC (1920 x 1080)
High-definition (HD) content is required to view high definition images.
Resolutions are dependent upon monitor capability and resolution and color depth settings.
HP Sure View integrated privacy screen is an optional feature that must be configured at purchase and is designed to function in landscape orientation.
Supported display resolutions
Supports resolutions up to 4K at 60 Hz via HDMI v1.4b
Storage/drives
Feature
Primary M.2 Solid State Drive storage
128 GB SATA-3 TLC SSD
256 GB PCIe NVMe Value SSD
256 GB PCIe Gen 3 x4 NVMe TLC SSD
256 GB PCIe Gen 3 x4 NVMe TLC Opal 2 SED SSD
256 GB PCIe QLC SSD with 16 GB Intel Optane Memory
512 GB PCIe NVMe Value SSD
512 GB PCIe Gen 3 x4 NVMe TLC SSD
512 GB PCIe Gen 3 x4 NVMe TLC Opal 2 SSD
512 GB Intel PCIe NVMe QLC SSD with 32 GB Intel Optane Memory
2 TB PCIe Gen 3 x4 NVMe TLC SSD
1 TB PCIe Gen 3 x4 NVMe TLC SSD
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Networking/communication
Feature
Wireless LAN (WLAN)
Intel Dual Band Wireless-AX201 802.11a/b/g/n/ac (2x2) Wi-Fi 6 and Bluetooth 5 Combo, non-vPro
Intel Dual Band Wireless-AX201 802.11a/b/g/n/ac (2x2) Wi-Fi 6 and Bluetooth 5 Combo, vPro
Wi-Fi 6 is backwards compatible with prior 802.11 specs.
Wireless access point and internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11 WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11 WLAN devices.
WWAN
Intel XMM 7360 LTE-Advanced Cat 9
WWAN module is an optional feature, requires factory configuration and requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds might vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, in all countries/regions.
Qualcomm Snapdragon X55 5G modem (5G and LTE CAT 20)
NFC
NPC300 Near Field Communication module (sold separately or as an optional feature)
PC locator
Built-in Tile module (select models)
Tile is an optional feature that must be configured at the factory and requires Windows 10. Some features require optional subscription to Tile Premium. Not available on models with WWAN M.2 module. Tile application for Windows 10 is available for download from the Windows Store. Mobile phone app available for download from App Store and Google Play. Requires iOS 11 and greater or Android 6.0.
Miracast support
Yes
Ports/slots
Feature
Ports
(2) USB Type-C ports (Thunderbolt, supports Power Deliver 3.0, DisplayPort 1.2)
(2) USB 3.1 Gen 1 ports (5 Gbps signaling rate)
(1) HDMI 1.4b (cable sold separately)
(1) Headphone/microphone combo jack
(1) AC power input port
Slot
(1) Nano SIM card slot (for WWAN)
All units have a SIM card stray but units that do not support WWAN are shipped with a non-removable SIM slot plug.
Audio/multimedia
Feature
Audio
Audio by Bang & Olufsen
(4) Premium Stereo Speakers
Microphones (multi-array including two user facing and two world-facing microphones)
Camera
Hybrid 720p HD/IR camera with integrated privacy shutter
HD content required to view HD images.
Sensors
Ambient light sensor
Hall Sensor
Magnetometer
Accelerometer
Gyroscope
Time of flight
Keyboard/pointing device/function keys
Feature
HP Quiet Keyboard
Spill resistant
Optional backlit keyboard, privacy, and DuraKeys
Pointing device
Glass clickpad with multi-touch gestures enabled (taps enabled as default)
Function keys
F1 – Display switching
F2 – Blank or Sure View
F3 – Brightness down
F4 - Brightness up
F5 - Audio mute/unmute
F6 - Volume down
F7 - Volume up
F8 - Microphone mute/unmute
F9 - Backlight toggle
F10 - Insert
F11 - Airplane mode
F12 - HP Programmable Key
Hidden Function Keys
Fn + R - Break
Fn + S - Sys rq
Fn + C - Scroll lock
Fn + E - Insert
Fn + W - Pause
Software/security
Feature
BIOS
HP BIOSphere Gen5 (available on select platforms)
HP Sure Start Gen6
BIOS Update via Network
Power On Authentication
Master Boot Record Security
HP Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
Absolute Persistence Module
Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Communication/connectivity
HP Connection Optimizer
HP Value add software
HP Presence Aware
HP Sure Recover Gen3 (requires internet connection and not for systems with multiple drives)
HP Hotkey Support
HP Image Assistant
HP Jumpstart
HP Workwell
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Management Integration Kit Gen4 for Microsoft SCCM (available for download)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Security
HP Client Security Manager Gen6 (requires Windows and available on select platforms)
HP Fingerprint Sensor
Windows Defender (opt in and internet connection required for updates)
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Other standard security features
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
HP Sure Click (available on select HP platforms and supports Internet Explorer, Google Chrome, and Chromium)
HP Sure Sense (requires Windows)
Support for chassis padlocks and cable lock devices
Power
Feature
Power adapters
HP Smart 65 W USB Type-C adapter
Availability might vary by country/region.
Power cord
1.0 m (3.28 ft) Premium C5 power cord
1.0 m (3.28 ft) Conventional C5 power cord
Primary battery
HP Long Life 4-cell, 54.5 Wh Li-ion polymer
HP Long Life 4-cell, 78.6 Wh Li-ion polymer
Battery is internal and not replaceable by customer. Serviceable by warranty.
Windows 10 MM14 battery life varies depending on various factors including product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Physical specifications
Feature
Starting at 1.32 kg (2.91 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
31.93 x 20.27 x 1.65 cm (12.57 x 7.98 x 0.65 in)
