1Y8K3PA
HP ENVY Laptop - 13-ba0072tx
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
16 GB DDR4-2666 SDRAM (onboard)
512 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD, IPS, BrightView, micro-edge, WLED-backlit, edge-to-edge glass and HP Sure View integrated privacy screen, 1000 nits, 72% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.69 cm
Starting at 1.3 kg
65 W Smart AC power adapter
3-cell, 51 Wh Li-ion
Battery life mixed usage
Up to 9 hours and 45 minutes
Video Playback Battery life
Up to 14 hours and 45 minutes
HP Wide Vision HD camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
- ${title}
- ${title}
- ${title}
- ${title}
HP ENVY Laptop - 13-ba0072tx Product Specifications
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
Alexa; ExpressVPN (30 day free trial); iQiyi; LastPass password manager (30 day free trial)
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
