238D4EA
HP Spectre x360 Laptop - 15-eb0009nw
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
16 GB DDR4-2666 SDRAM (onboard)
Video graphics
NVIDIA® GeForce® MX330 (2 GB GDDR5 dedicated)
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, 4K UHD (3840 x 2160), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, anti-reflection Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 HDMI 2.0a; 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 AC smart pin; 1 headphone/microphone combo
35.99 x 22.64 x 1.99 cm
2.45 kg
90 W Smart AC power adapter
6-cell, 72.9 Wh Li-ion polymer
Battery life mixed usage
Up to 11 hours and 15 minutes
Video Playback Battery life
Up to 13 hours and 30 minutes
HP True Vision 720p HD IR camera with integrated dual array digital microphones
Audio by Bang & Olufsen, quad speakers, HP Audio Boost 2.0
- ${title}
- ${title}
- ${title}
- ${title}
HP Spectre x360 Laptop - 15-eb0009nw Product Specifications
Windows 10 Pro 64
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix; ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
