HP Notebook - 14-ck2008nm Product Specifications
1V2L5EA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
Intel® Integrated SoC
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD SVA anti-glare WLED-backlit, 220 nits, 45% NTSC (1920 x 1080)
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
33.5 x 23.4 x 1.99 cm
Starting at 1.5 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 9 hours and 15 minutes
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS
