    Apache Log4j Update
HP Notebook - 15-db1235ur Product Specifications
1V2N9EA
AMD Ryzen™ 5 3500U (2.1 GHz base clock, up to 3.7 GHz max boost clock, 4 MB L3 cache, 4 cores)
AMD Integrated SoC
16 GB DDR4-2400 SDRAM (2 x 8 GB)
Video graphics
AMD Radeon™ Vega 8 Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
Starting at 1.8 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
FreeDOS
