    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP ENVY x360 Laptop - 13-ay0102au Product Specifications
1F5E4PA
AMD Ryzen™ 7 4700U (2.0 GHz base clock, up to 4.2 GHz max boost clock, 4 MB L2 cache, 8 cores)
16 GB DDR4-3200 SDRAM (onboard)
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD, IPS, BrightView, micro-edge, WLED-backlit, multitouch-enabled, edge-to-edge glass with Corning® Gorilla® Glass NBT™, 300 nits, 72% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 200 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.64 cm
Starting at 1.32 kg
65 W Smart AC power adapter
3-cell, 51 Wh Li-ion
HP Wide Vision HD Camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
Windows 10 Home 64 Plus
HP Command Center; HP Connection Optimizer; HP Documentation; HP e-Service; HP JumpStart; HP PC Hardware Diagnostics Windows; HP Support Assistant
Pre-installed software
ExpressVPN (30 day free trial); iQiyi; LastPass password manager (30 day free trial)
