1U2Y1EA
HP Laptop - 14s-fq0700nd
AMD 3020e (1.2 GHz base clock, up to 2.6 GHz max boost clock, 4 MB L3 cache, 2 cores)
AMD Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ Graphics
128 GB SATA3 TLC M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
32.4 x 22.5 x 1.79 cm
1.46 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours and 30 minutes
Video Playback Battery life
Up to 8 hours and 45 minutes
HP True Vision 720p HD camera with integrated dual array digital microphone
Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Laptop - 14s-fq0700nd Product Specifications
Windows 10 Home in S mode
HP 3D DriveGuard; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix; ExpressVPN (30 day free trial)
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
