HP Pavilion Gaming Laptop - 15-dk1027nm Product Specifications
1Z9N0EA
Intel® Core™ i5-10300H (2.5 GHz base frequency, up to 4.5 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® HM470
16 GB DDR4-2933 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit, 300 nits, 72% NTSC (1920 x 1080)
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36 x 25.6 x 2.34 cm
2.23 kg
200 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
Battery life mixed usage
Up to 6 hours
Video Playback Battery life
Up to 9 hours
HP Wide Vision 720p HD camera with integrated dual array digital microphone
Audio by B&O; Dual speakers; HP Audio Boost 1.0
FreeDOS
