HP Notebook - 15-db0027ne Product Specifications
187B1EA
AMD A9-9425 (3.1 GHz base clock, up to 3.7 GHz max boost clock, 1 MB L2 cache, 2 cores)
8 GB DDR4-1866 SDRAM (1 x 8 GB)
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal HD SVA anti-glare WLED-backlit (1366 x 768)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
1.77 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 7 hours and 30 minutes
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS
