OMEN Laptop - 15-en0021nd Product Specifications
1N3L6EA
AMD Ryzen™ 5 4600H (3.0 GHz base clock, up to 4.0 GHz max boost clock, 3 MB L2 cache, 6 cores)
AMD Integrated SoC
8 GB DDR4-3200 SDRAM (2 x 4 GB)
Video graphics
  • AMD Radeon™ Graphics
  • Discrete
  • NVIDIA® GeForce® GTX 1650 Ti (4 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD, IPS, anti-glare, micro-edge, WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 200 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 5Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 Mini DisplayPort™; 1 HDMI 2.0a; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.79 x 23.97 x 2.25 cm
Starting at 2.37 kg
150 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
HP Wide Vision 720p HD camera with integrated dual array digital microphone
Audio by Bang & Olufsen; DTS:X® Ultra; OMEN Audio Control Support DTS:X® Ultra; Dual speakers; HP Audio Boost 2.0
Pre-installed software
Netflix
