    Windows 11 Upgrade Guide
HP LaserJet MFP M232-M237 printers - First time printer setup
This document is for HP LaserJet MFP M232dw, M232dwc, M233sdn, M233sdw, M233dw, M234sdwe, M234sdw, M234sdne, M234sdn, M234dwe, M234dw, M236sdn, M236sdw, M236dw, and M236d printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, connect the printer to a power source, download and install HP Smart or the printer software, connect the printer to a network, create an HP Account, and then load paper.
If you are looking for the printer software, go to 123.hp.com.
Step 1: View an overview video
Step 2: Remove the printer from the box
Remove the printer from the box, and then remove the packing material.
  1. Remove the printer and power cord from the box.
  2. Remove and recycle all packing material.
    Removing the packing materials
    Do not remove the toner cartridge from the printer. The printer is shipped with the toner cartridge already prepared for printing.
  3. Remove the tape, and then gently pull out the orange toner sheet.
    Pulling out the toner sheet
Step 3: Install paper tray, tray cover, and load paper
Install paper tray, tray cover, and then load paper in the input tray.
Step 4: Connect the power cord and turn on the printer
Plug the power cord into a wall outlet and turn on the printer.
Do not connect a USB cable at this time.
    Connecting the power cord
  2. Turn on the printer.
    HP+ printers must be connected to the internet (Wi-Fi or wired). If you want to use a USB cable, connect your HP+ printer to internet first, and then connect the USB cable as secondary connection.
Step 5: Install the printer software, connect the printer to your device, and complete setup
Use the HP Smart app or HP Easy Start to help you set up the printer and connect the printer to a wireless network (preferred) or USB connection.
An HP account is required. If you do not have an account, you can create one during the software installation process.
For more information, refer the following videos to set up your printer:
The following setup videos are applicable only for the following HP+ printers: HP LaserJet M209dwe, HP LaserJet MFP M234dwe, M234sdwe, and M234sdne models which are sold only in certain countries/regions.
