    Apache Log4j Update
HP Pavilion x360 - 15-dq1152ng Product Specifications
1B2D6EA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
Intel® Integrated SoC
Video graphics
Intel® UHD Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass, 250 nits, 45% NTSC (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4; 1 headphone/microphone combo;
35.9 x 24.16 x 2.07 cm
Starting at 1.92 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Audio by B&O; Dual speakers; HP Audio Boost 1.0
Pre-installed software
Netflix
