15V20EA
HP Spectre x360 Laptop - 15-eb0016nf
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2666 SDRAM (onboard)
Video graphics
NVIDIA® GeForce® MX330 (2 GB GDDR5 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal 4K UHD, IPS, micro-edge, WLED-backlit, multitouch-enabled, edge-to-edge glass with anti-reflection Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB (3840 x 2160)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 HDMI 2.0a; 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 AC smart pin; 1 headphone/microphone combo
35.99 x 22.64 x 1.99 cm
Starting at 1.92 kg
90 W Smart AC power adapter
6-cell, 72.9 Wh Li-ion polymer
Battery life mixed usage
Up to 11 hours and 15 minutes
Video Playback Battery life
Up to 13 hours and 30 minutes
HP True Vision 720p HD IR camera with integrated dual array digital microphone
Audio by Bang & Olufsen, quad speakers, HP Audio Boost 2.0
- ${title}
- ${title}
- ${title}
- ${title}
HP Spectre x360 Laptop - 15-eb0016nf Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix; ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
