    Windows 11 Upgrade Guide
HP Notebook - 15-da2207ne Product Specifications
186Y7EA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
Intel® Integrated SoC
Video graphics
NVIDIA® GeForce® MX130 (4 GB GDDR5 dedicated)
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal, HD (1366 x 768), BrightView, 220 nits, 45% NTSC
2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 USB 2.0 Type-A; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
2.04 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 8 hours and 45 minutes
HP True Vision 720p HD camera with integrated digital microphone
Dual speakers
FreeDOS
