Product Specifications for the HP Laser NS MFP 1005n (4YE56A)
Product naming
Model name
4YE56A
What's included and accessories
What's in the box
HP Laser NS 1005w Printer; Preinstalled HP Black Original Imaging Drum (~2500 pages yield, ~20000 pages useful life); Reference guide; Setup guide; Regulatory flyer; Support flyer; Warranty guide; Power cord; USB cable
Connectivity
Ports
Hi-Speed USB 2.0 port; Fast Ethernet 10/100 Base
Wireless capability
No
Environmental
Acoustic power emissions (active, printing)
6.5 B(A)
Recommended operating humidity range
30 to 70% RH
Recommended operating temperature range (Celsius)
17.5 to 25°C
Storage temperature range (Celsius)
-20 to 50°C
Environmental specifications
Mercury-free
Fax
Fax transmission speed note
N/A
Memory
Memory
64 MB
Maximum Memory
64 MB
Mobile printing capability
Mobile printing services
Apple AirPrint™; Google Cloud Print™; HP Smart App; Mopria™ Certified
Mobile printing compatibility note
Apple AirPrint -Mobile device must have AirPrint®. Wireless operations are compatible with 2.4 GHz operations only. Learn more at hp.com/go/mobileprinting. Google Cloud Print™ 2.0- Requires Google Cloud Print™ registration and Google account. Wireless operations are compatible with 2.4 GHz operations only. Learn more at http://hp.com/go/mobileprinting.
Paper handling
Input capacity
Up to 150 sheets
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A6; A5; A4; Letter; No.10 Env; C5 Env; DL Env; B5(JIS); 105 x 148.5 mm to 215.9 x 297 mm
Media sizes, custom (metric)
105 x 148.5 to 215.9 x 297 mm
Media types
Plain paper, Heavy paper, Bond paper, Label, Light paper, Envelope
Media weight supported (metric)
60 to 120 g/m²
Physical dimensions
Maximum dimensions (W x D x H, metric)
380.5 x 385 x 521 mm
Weight (metric)
8.73 kg
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology
Internal (Built-in) power supply
Power supply
110V - 127V nominal @ +/-10% (min 99V, max 140V), 50 - 60Hz nominal +/- 3Hz (min 47Hz, max 63Hz), 220V - 240V nominal @ +/-10% (min 198V, Max 264V), 50 - 60Hz nominal +/- 3Hz (min 47Hz, max 63Hz)
Power consumption
338 watts (Active Printing), 3.3 watts (Ready), 0.95 watts (Sleep), 0.1 watts (Manual off)
Print cartridges
Number of print cartridges
1 Imaging Drum
Replacement cartridges
HP 108A Black Original Laser NS Toner Reload Kit (Yield ~2500 pages); HP 108AD Dual pack Black Original Laser NS Toner Reload Kit (Yield ~2x2500 pages); HP 109A Black Original Laser Imaging Drum (includes ~5000 pages of inbox toner, useful life of ~20000 pages)
Replacement cartridges footnote
Declared black toner page yield value in accordance with ISO/IEC 19752 and continuous printing. Actual yields vary considerably based on images printed and other factors. For details see http://www.hp.com/go/learnaboutsupplies
SureSupply note
HP SureSupply alerts you when your print cartridge is running low and helps you purchase online or locally through HP or a participating retailer. For more information, visit http://www.hp.com/go/SureSupply; only available with Original HP supplies; Internet access required.
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 600 x 600 x 2 dpi
Monthly duty cycle
Up to 20000 pages
Print languages
PCLmS; URF; PWG
Printer smart software features
Apple AirPrint™, Mopria-certified, HP Auto-On/Auto-Off, HP Smart App, HP Smart Task
Regulatory specifications
Regulatory model number
SEOLA-1800-02
Energy efficiency
CECP
Safety
GB4943.1-2011
Electromagnetic compatibility
GB17625.1-2012
Scan
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 600 dpi
Levels of grayscale
256
Bit depth
24-bit
Twain version
Version 2.1 (Windows 7 or higher)
System requirements
Minimum system requirements for Windows
Windows® 10, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer.
Minimum System Requirements for Macintosh
macOS Sierra (v10.12) macOS High Sierra (v10.13) macOS Mojave (v10.14) macOS Catalina (v10.15); 1.5 GB HD; Internet required; USB
Compatible Network Operating Systems
Windows® 10, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. macOS Sierra (v10.12) macOS High Sierra (v10.13) macOS Mojave (v10.14) macOS Catalina (v10.15); 1.5 GB HD; Internet required; USB Linux (For more information, see https://developers.hp.com/hp-linux-imaging-and-printing)
Operating system (supported note)
Not supporting Windows® XP (64-bit) and Windows Vista® (64-bit). Not all "Compatible Operating Systems" are supported with INBOX software; Full solution software available only for Windows 7 and newer; For Windows Server 2008 R2 64-bit, 2012 64-bit, 2012 R2 64-bit, 2016 64-bit only print driver is installed. Windows RT OS for Tablets (32 & 64-bit) uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software.
HP one year hardware limited warranty. For full terms and conditions, visit: http://www.hp.com/go/orderdocuments.
