1Y530UA
HP Laptop - 14-dk1018ca
AMD Athlon™ Gold 3150U (2.4 GHz base clock, up to 3.3 GHz max boost clock, 1 MB L2 cache, 2 cores)
Video graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
14" diagonal HD SVA BrightView micro-edge WLED-backlit (1366 x 768)
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
32.4 x 22.59 x 1.99 cm
1.47 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 15 minutes
Video Playback Battery life
Up to 11 hours
HP TrueVision HD Camera with integrated digital microphone
Stereo speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Laptop - 14-dk1018ca Product Specifications
HP Connection Optimizer; HP BIOS Protection; HP Audio Switch; HP Games by WildTangent; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
