    Windows 11 Upgrade Guide
HP Pavilion x360 Laptop - 14-dh2075nr Product Specifications
9VB20UA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
8 GB DDR4-3200 SDRAM (1 x 8 GB)
Video graphics
  • Intel® UHD Graphics
  • Integrated
  • 256 GB PCIe® NVMe™ M.2 SSD
  • [16,17]
Optical drive
Optical drive not included
14" diagonal HD micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Realtek Wi-Fi 5 (2x2) and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4; 1 AC smart pin; 1 headphone/microphone combo
32.4 x 22.29 x 1.97 cm
1.58 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 12 hours and 15 minutes
Video Playback Battery life
Up to 7 hours and 45 minutes
Audio by B&O; Dual speakers
HP Connection Optimizer; HP Audio Switch; HP BIOS Protection; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
