    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 15-dw1002nu Product Specifications
10B34EA
HP Notebook - 15t-dw100
Intel® Core™ i3-10110U (2.1 GHz base frequency, up to 4.1 GHz base with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
Intel® Integrated SoC
Video graphics
Intel® UHD Graphics
  • 128 GB M.2 SSD
  • 1 TB 5400 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.78 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
FreeDOS
