    Fix HP Printer issue on macOS
HP Notebook - 15-da2210nia Product Specifications
9HJ82EA
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal HD SVA BrightView WLED-backlit, 220 nits, 45% NTSC (1366 x 768)
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
37.6 x 24.6 x 2.25 cm
2.04 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 8 hours and 45 minutes
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
FreeDOS
