    Windows 11 Upgrade Guide
HP Laptop - 15s-eq0037nq Product Specifications
2S967EA
AMD Ryzen™ 5 3500U with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
8 GB DDR4-2400 SDRAM (2 x 4 GB)
Video graphics
AMD Radeon™ Vega 8 Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit, 220 nits, 45% NTSC (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
35.85 x 24.2 x 1.79 cm
1.74 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 8 hours and 30 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
FreeDOS
