    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP ScanJet Pro 2000 s2, 3000 s4, N4000 snw1 / HP ScanJet Enterprise Flow 5000 s5, 7000 s3, N7000 snw1 - Scanner software (Windows)
The scanner comes with a variety of Windows scanning software and drivers, including HP Scan.
HP Scan software
Use the HP Scan software to complete the following tasks:
  • Scan to a PDF
  • Scan to a JPEG
  • Email as a PDF
  • Email as a JPEG
  • Scan text for editing (OCR)
  • Scan to cloud
  • Everyday scan
HP Scanner Tools Utility
Use the HP Scanner Tools Utility to complete the following tasks:
  • Set maintenance and status update notification options
  • Change the scanner's power management settings
  • View scanner information (firmware version, serial number, total number of pages scanned)
  • Modify scan profiles
  • Modify properties of Scan to USB Drive
To open the utility, do one of the following:
  • Windows 8.1 and 10: On the Start screen, click the HP Scanner Tools Utility tile.
  • Launch HP Scan Assistant from your desktop, and then select Tools.
HP TWAIN
HP TWAIN provides a software interface between imaging/scanning hardware and TWAIN-compliant software applications. Not all TWAIN-compliant software works in the same way, so consult the software documentation for details on how to acquire scans.
ISIS
ISIS (Image and Scanner Interface Specification) provides a software interface between imaging/scanning hardware and ISIS based software applications. ISIS drivers provide a consistent interaction with all ISIS-compliant scanners.
WIA
WIA provides a software interface between imaging/scanning hardware and WIA-compliant software applications. Not all WIA-compliant software works in the same way, so consult the software documentation for details on how to acquire scans.
