    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
Document ID: c06587263
Version: 1
HP Elite Dragonfly, EliteBook X360 1030 G4 PCs - LED Indicating Airplane Mode Is on Does Not Illuminate When the Computer Resumes From Hibernation, or From a Power Off State
Release date : 06-Mar-2020
Last updated : 06-Mar-2020
DESCRIPTION
The LED indicating Airplane mode is on does not illuminate. This occurs when Airplane mode is on when the computer enters, then resumes from hibernation, or from a power off state. The LED on the F11 key is off, but should be amber in color when in use.
SCOPE
The information in this document applies to the following:
Drivers:
Intel(R) XMM(TM) 7560 LTE-Advanced Pro (Cat16) Drivers, v2.6.32.42,A,1
Hardware:
Intel® XMM™ 7560 LTE-Advanced Pro CAT16 WWAN module
Computers:
  • HP Elite Dragonfly Notebook PC
  • HP EliteBook x360 1030 G4 Notebook PC
Operating Systems:
Microsoft Windows 10 19H1 (Version 1903)
RESOLUTION
To recover from this issue, press the F11 key twice.
To resolve this issue, download and install the following SoftPaq to update the WWAN Driver:
SoftPaq Description
Release Notes
Download SoftPaq
HP XMM7560 WWAN Driver
Version: 2.6.32.215
Revision: A
A more recent version of this software may be available. Check for newer versions at: http://www.hp.com/drivers.
Hardware platforms affected : HP Elite Dragonfly Notebook PC, HP EliteBook x360 1030 G4 Notebook PC
Support Communication Cross Reference ID : IA06587263
