    Are you working from home?
Product Specifications for the HP Neverstop Laser MFP 1200nw (5HG85A)
Product naming
Model name
5HG85A
What's included and accessories
What's in the box
HP Neverstop laser1200nw Printer; Preinstalled HP Black Original Imaging Drum (~5000 pages yield, ~20000 pages useful life); Reference guide; Setup guide; Regulatory flyer; Support flyer; Warranty guide; Power cord; USB cable
Connectivity
Ports
Hi-Speed USB 2.0 port; Built-in WiFi 802.11b/n/g; Fast Ethernet 10/100 Base
Wireless capability
Yes
Copy
Copier settings
Number of Copies; Lighter/Darker; Optimize; Paper
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed (black, normal)
Up to 20 cpm
Copy resolution
Up to 600 x 600 dpi (flatbed)
Environmental
Acoustic power emissions (active, printing)
6.5 B(A)
Recommended operating humidity range
30 to 70% RH
Recommended operating temperature range (Celsius)
17.5 to 25°C
Recommended operating temperature range (Fahrenheit)
63.5 to 77°F
Storage temperature range (Celsius)
-20 to 50°C
Storage temperature range (Fahrenheit)
-4 to 122°F
Environmental specifications
Mercury-free
Memory
Memory
64 MB
Maximum Memory
64 MB
Mobile printing capability
Mobile printing services
Apple AirPrint™; Google Cloud Print™; HP Smart App; Mopria™ Certified; Wi-Fi® Direct Printing
Mobile printing compatibility note
Apple AirPrint -Mobile device must have AirPrint®. Wireless operations are compatible with 2.4 GHz operations only. Learn more at hp.com/go/mobileprinting. Google Cloud Print™ 2.0- Requires Google Cloud Print™ registration and Google account. Wireless operations are compatible with 2.4 GHz operations only. Learn more at hp.com/go/mobileprinting.
Networking
Network protocols, supported
TCP/IP: IPv4; IPv6; IP Direct Mode; LPD; SLP; Bonjour; WS-Discovery; BOOTP/DHCP/AutoIP; SNMP v 1/2/3; HTTP/HTTPS
Paper handling
Input capacity
Up to 150 sheets
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A6; A5; A4; Letter; No.10 Env; C5 Env; DL Env; B5(JIS); Oficio 216 x 340; Legal; 105 x 148.5 mm to 216 x 356 mm
Media sizes supported (U.S. standard)
Letter; envelopes (No.10); custom
Media sizes, custom (metric)
Media sizes, custom (U.S. standard)
4.13 x 5.85 to 8.5 x 14
Media types
Plain paper, Heavy paper, Bond paper, Label, Light paper, Envelope
Media weight supported (metric)
60 to 120 g/m²
Media weight supported (U.S. standard)
14 to 27 lb
Physical dimensions
Maximum dimensions (W x D x H, metric)
380.5 x 385 x 521 mm
Maximum dimensions (W x D x H, U.S. standard)
14.98 x 15.16 x 20.51 in
Weight (metric)
8.78 kg
Weight (U.S. standard)
19,.36 lb
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology
Internal (Built-in) power supply
Power supply
110V - 127V nominal @ +/-10% (min 99V, max 140V), 50 - 60Hz nominal +/- 3Hz (min 47Hz, max 63Hz), 220V - 240V nominal @ +/-10% (min 198V, Max 264V), 50 - 60Hz nominal +/- 3Hz (min 47Hz, max 63Hz)
Power consumption
338 watts (Active Printing), 3.3 watts (Ready), 0.95 watts (Sleep), 0.1 watts (Manual off)
Print cartridges
Number of print cartridges
1 Imaging Drum
Replacement cartridges
HP 103A Black Original Neverstop Laser Toner Reload Kit (Yield ~2500 pages); HP 103AD Dual pack Black Original Neverstop Laser Toner Reload Kit (Yield ~2x2500 pages); HP 104A Black Original Laser Imaging Drum (includes ~5000 pages of inbox toner, useful life of ~20000 pages)
Replacement cartridges footnote
Declared black toner page yield value in accordance with ISO/IEC 19752 and continuous printing. Actual yields vary considerably based on images printed and other factors. For details see http://www.hp.com/go/learnaboutsupplies. HP W1103A and HP W1104A replacement supplies are not imported, sold, nor warrantied in China.
SureSupply note
HP SureSupply alerts you when your print cartridge is running low and helps you purchase online or locally through HP or a participating retailer. For more information, visit http://www.hp.com/go/SureSupply; only available with Original HP supplies; Internet access required.
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 600 x 600 x 2 dpi
Maximum print area (metric)
216 x 356 mm
Monthly duty cycle
Up to 20,000 pages
Print languages
PCLmS; URF; PWG
Printer smart software features
Apple AirPrint™, Mopria-certified, HP Auto-On/Auto-Off, Wi-Fi Direct, HP Smart App, HP Smart Task
Regulatory specifications
Regulatory model number
SEOLA-1800-03
Safety
IEC 60950-1: 2005 +A1: 2009 +A2 2013 (International); EN 60950-1: 2006 +A11: 2009 +A1: 2010 +A12: 2011 +A2: 2013 (EU); IEC/EN 60825-1: 2014 (Class 1 Laser Product); EN 62479: 2010 /IEC 62749: 2010; Low Voltage Directive 2006/95/EC with CE Mark (Europe); UL/cUL Listed and UC CoC (US/Canada); CAN/CSA C22.2 No. 60950-1-07 2nd Ed. 2014-10; Compliance with Laser safety standards 21 CFR 1002.10 and 1002.11 except for deviations pursuant to Laser notice No. 50, Dated June 24, 2007; Other safety approvals as required by individual countries IS 13252(PART 1): 2010
Electromagnetic compatibility
EN 61000-3-2: 2014, EN 61000-3-3: 2013, EN55024: 2010, EN 55032: 2012/AC: 2013, 47 CFR Part 15, Subpart B I ANSI C63.4-2009, ICES-003 Issue 5, KN32, KN35, GB/T 9254-2008, GB17625.1-2012, CISPR22: 2008, CISPR32: 2012,CNS 13438 (Other EMC approvals as required by individual countries).
Scan
Scanner advanced features
No
Scan technology
D-CIS
Scan resolution, hardware
Up to 600 ppi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.7 in
Twain version
Version 2.1 (Windows 7 or higher)
System requirements
Minimum system requirements for Windows
Windows® 10, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer.
Minimum System Requirements for Macintosh
Apple®OS X EI Capitan (v10.11) macOS Sierra (v10.12) macOS High Sierra, (v10.13); 1.5 GB HD; Internet required; USB
Compatible Network Operating Systems
Windows® 10, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. Apple®OS X EI Capitan (v10.11) macOS Sierra (v10.12) macOS High Sierra, (v10.13); 1.5 GB HD; Internet required; USB Linux (For more information, see https://developers.hp.com/hp-linux-imaging-and-printing
Operating system (supported note)
Not supporting Windows® XP (64-bit) and Windows Vista® (64-bit). Not all "Compatible Operating Systems" are supported with INBOX software; Full solution software available only for Windows 7 and newer; For Windows Server 2008 R2 64-bit, 2012 64-bit, 2012 R2 64-bit, 2016 64-bit only print driver is installed. Windows RT OS for Tablets (32 & 64-bit) uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software.
HP one year hardware limited warranty. For full terms and conditions, visit: http://www.hp.com/go/orderdocuments.
