Document ID: c06572866
Version: 5
HP Commercial Desktops, Notebooks, and Thin Clients PCs - Installing or Upgrading to Windows 10 Version 2004 or Installing KB4524244 or KB4535680 Results in Hang
Release date : 19-Feb-2020
Last updated : 19-Feb-2020
DESCRIPTION
The computer hangs while installing Microsoft Windows 10 version 2004 or after attempting to update the operating system to the latest patch as of February 11, 2020 Update (all versions). After restarting the computer, a HP Sure Start Recovery warning message will appear. The following messages are seen:
Figure 1. HP Sure Start Recovery warning message
The following message appears when viewing the Windows updates status:
Figure 2. Window Updates failed message
This issue also occurs while installing Microsoft Windows 10 version 2004.
SCOPE
Notebook Computers:
  • HP EliteBook 735 G5 Notebook PC
  • HP EliteBook 735 G6 Notebook PC
  • HP EliteBook 745 G5 Notebook PC
  • HP EliteBook 745 G6 Notebook PC
  • HP EliteBook 755 G5 Notebook PC
  • HP ProBook 645 G4 Notebook PC
  • HP mt44 Mobile Thin Client
  • HP mt45 Mobile Thin Client
Desktop Computers:
  • HP EliteDesk 705 35W G4 Desktop Mini PC
  • HP EliteDesk 705 65W G4 Desktop Mini PC
  • HP EliteDesk 705 G4 Microtower PC
  • HP EliteDesk 705 G4 Small Form Factor PC
  • HP EliteDesk 705 G4 Workstation Edition
  • HP EliteDesk 705 G5 Desktop Mini PC
  • HP EliteDesk 705 G5 Small Form Factor PC
  • HP ProDesk 405 G4 Small Form Factor PC
Operating Systems:
Microsoft Windows 10 (All Versions)
RESOLUTION
To prevent this issue from occurring, please upgrade to latest BIOS before proceeding to install or update to the latest Windows 10 version 2004 or re-installing the KB4524244 or KB4535680.
To recover from this issue, perform the following steps:
  1. Power on or restart the computer.
  2. If the HP Sure Start Recovery warning message appears, select OK.
    If the computer boots successfully into Windows, do not install the updates. The updates will continue to fail when installed.
    If the computer does not boot into Windows successfully, then proceed to Step 3.
  3. Press the F10 key to enter HP Computer Setup (F10 Setup).
  4. Select Security>BIOS Sure Start.
  5. Uncheck the Sure Start Secure Boot keys protection option to disable it.
  6. Save changes and exit the BIOS.
  7. Complete the pending Windows update installation. After the performing the updates, manually re-enable Sure Start Secure Boot keys protection option.
  8. Restart the computer.
  9. Press the F10 key to enter HP Computer Setup (F10 Setup).
  10. Select Security>BIOS Sure Start.
  11. Check the Sure Start Secure Boot keys protection option to enable.
  12. Save changes and exit the BIOS.
NOTE: If the issue persists, then refer to the following article:
NOTE: Microsoft has removed the Windows update (KB4524244) and will no longer offer this KB4524244. This update will be re-released as KB4535680 by January 10/2021.
If the latest supported BIOS is not installed on the system, then Windows 2004 installation, Windows 2004 Update, or the KB4524244 or KB4535680 update may be blocked for installation or download.
HP recommends that the latest BIOS is installed before updating or installing Windows 2004 or installing the KB4524244 or KB4535680.
Models Affected
BIOS Version
Download SoftPaq
02.13.00
02.13.00
02.13.00
02.13.00
02.13.00
02.06.00
HP EliteDesk 705 G5 Desktop Mini HP PC
02.06.00
02.13.00
01.06.00
01.06.00
HP MT45 THIN CLIENT
01.06.00
01.12.00
01.12.00
01.12.00
HP MT44 THIN CLIENT
01.12.00
01.12.00
NOTE: A more recent version of this software may be available. Check for newer versions at: http://www.hp.com/drivers
Hardware platforms affected : HP EliteBook 735 G5 Notebook PC, HP EliteBook 735 G6 Notebook PC, HP EliteBook 745 G5 Notebook PC, HP EliteBook 745 G6 Notebook PC, HP EliteBook 755 G5 Notebook PC, HP EliteDesk 705 35W G4 Desktop Mini PC, HP EliteDesk 705 65W G4 Desktop Mini PC, HP EliteDesk 705 G4 Microtower PC, HP EliteDesk 705 G4 Small Form Factor PC, HP EliteDesk 705 G4 Workstation Edition, HP EliteDesk 705 G5 Desktop Mini PC, HP EliteDesk 705 G5 Small Form Factor PC, HP ProBook 645 G4 Notebook PC, HP ProDesk 405 G4 Small Form Factor PC, HP mt44 Mobile Thin Client, HP mt45 Mobile Thin Client
Support Communication Cross Reference ID : IA06572866
